Re: Farmall 706D piston grooves
Posted by rustyfarmall on October 27, 2009 at 14:01:36 from (209.152.78.140):
In Reply to: Farmall 706D piston grooves posted by freddy on October 27, 2009 at 13:58:36:
With only 2,000 hours on a rebuild, I doubt if the rest of the engine would benefit much from new rings.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
