Tom 43 said: (quoted from post at 12:35:18 10/27/09) The solenoid controls the LOAD or high speed circuit in the carburetor. Smoking at idle should be cured by backing out the idle mixture screw. On this carburetor counter clockwise is leaner on the IDLE screw. Another possibility is a needle and seat that is intermittently leaking fuel. Another possibility is the idle air bleed or the air supply for the idle air mixture screw being plugged. Still another is a plugged air cleaner. An M Farmall does not need high octane fuel, that is just nonsense.
The idle air bleed screw went away with the M carburetor. The idle mixture screw on the 706 is a fuel adjust screw, not air adjust.
Turning the screw clockwise will go lean, counterclockwise will screw it out and allow a richer mixture. This is just the opposite of the way the adjustment works on the M and H models.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
