Re: cheap weight
Posted by Stumpy on October 27, 2009 at 16:47:24 from (71.255.158.26):
In Reply to: cheap weight posted by Pat-CT on October 27, 2009 at 10:51:21:
I"d go looking for used tire weights to toss into a front mounted box.
Or if it"s rear weight, check out a plastic 55 gal drum and fill it with water.
Old schoolbus hyd brake rotors, Car sized brake rotors stack real easy on a rod or bar and are a heck of a lot cheaper as scrap than new steel.
A chunck of granite.
Cast some rebar into some concrete as mounting points and hang it under the tractor where needed.
use what"s cheap and easy to obtain
Hope that helps
Stumpy
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
