well the one drain plug for the rear end is up under the drawbar if ya have three point and you will have to drop the drawbar pin and and slide the drawbar back , Then there be two drain plugs one for each bull gear (they do not fill from the main fill hole and each has to be filled thru there own fill check plug located on the side and to the rear of the axles) . Then there are two drain plugs up under the center section . And ya might as well just get 5 five gallon buckets of Hy Tran and you will be just about wright with a little left over for later .
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
