I4 water pump
Posted by henryv1111 on October 27, 2009 at 16:49:30 from (64.81.231.198):
Well I got the radiator off the I 4 ok. Is it hard to remove the driver pin from the driver on the water pump.Once I get the driver and the fan off I will be able to remove the water pump and replace it with the new one.I got the nut and set screw lose on the adj pulley had to heat the housing up a little to loosen the set screw piece of cake with the rad off.Just kind of worried about that driver pin. I got the nut off but did not know haw much to tap it.
Thank you.
