Re: Brakes on Farmall H
Posted by Andrew Z on October 28, 2009 at 10:40:53 from (64.252.130.179):
In Reply to: Brakes on Farmall H posted by FarmallBear on October 28, 2009 at 10:32:22:
yes that is correct the super h's have disk and the h has band brakes. they are easy to tell apart the band brakes will have sheet metal covers on them and the disk ones will have a heavy cast outer cover. as for looking at the rear end without the brakes in place the drum brake cover will have around 6 3/8" bolts hold the cover in place. the disk brake will have 5 7/16" bolts holding them in place.
also type in super h disk and h band brake into google image and it should pop up a pic
Andrew
