Posted by Larry B 1486 on October 28, 2009 at 13:28:55 from (74.143.86.18):
In Reply to: 560 turbo diesel posted by big kahuna on October 28, 2009 at 08:58:25:
I put a turbo on my old 560 some years back, don't have the tractor anymore and also on a 706 that I once owned. M&W made a kit for the D282 motor and I seen one on ebay a few days ago. I set mine up just like the M&W but made the parts myself because I use to work in a machine shop. I used the orignal manifold just took out the pipe and made me a plate with the bolt hole pattern as the turbo welding onto the manifold but you have to set the turbo crossways on thoes motors with the intake faceing to the left side of the tractor. I also took off the oil bath air cleaner and got one off a 656 that mounts on the front of the motor and put a pipe thru the hood with the breather cap like on a 1206. I took picturs of it after I finished it but will not be home untill this weekend but can try to post them if you like when I get back home. You also have to put a nipple in the timing cover, I brazed one in a 90 deg. for the oil return hose and a tee in the oil sending unit for the oil supply line. The best thing to do is see if you can find pictures of a M&W set up that will help a lot. I also used a 3" straight pipe that made it sound good. I had mine running about 80hp
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
