Re: 560 turbo diesel
Posted by Larry B 1486 on October 28, 2009 at 13:51:07 from (74.143.86.18):
In Reply to: Re: 560 turbo diesel posted by Rick(MN) on October 28, 2009 at 13:31:57:
Rick. That was a IH factory turbo kit. I have never seen pictures of thoes and have tried to find info on them. I read they came with a dry airfilter but did not know they mounted on top and also came with a straight pipe. Did they use a different exhaust manifold and which direction did the turbo set?
