Re: hyd auger use with an M
Posted by redblood on October 28, 2009 at 13:52:51 from (64.12.116.77):
In Reply to: Re: hyd auger use with an M posted by farmallhal on October 27, 2009 at 08:25:07:
Wardner said: (quoted from post at 21:18:03 10/28/09) It's a speed control from zero to full output. Yes,
it functions as a bypass.
So in other words if the valve is shut off the motor receives full pressure , but when opened it reduces line pressure (bleeds off).
Actually then what you are doing is setting head pressure at the motor and to shut the auger off you open the valve so there is no pressure just a flow.
Damn simple thinking, but it works. Basically creating a pressure leak.
I am glad I was not the only one dumbstruck at first.
Thank you for clarifying this.
Joe
