Bob M said: (quoted from post at 22:27:27 10/28/09) Mike - Early production light switches had a fuseholder on the backside of the switch. Later production use a separate fuseholder mounted in the ammeter panel cover.
I recommend a 20 amp fuse in the supply to the light switch. You can do this a couple ways:
1 - Get a cartridge fuse holder, drill a hole in the ammeter cover and mount it as in the later production tractors. (Try Radio Shack or the CIH dealer for the fuseholder.) Use an AGC20 glass fuse in the holder.
2 - Use a modern blade-type fuse and fuse holder and tuck it inside the ammeter box. (A blade fuse holder runs about $1 at any auto parts store.)
Option # 3: Use a 20 amp self resetting circuit breaker.
A fuse holder works Okay for standard lighting but when you add a light or three you can find that the connection between the fuse and the holder is not good enough and will cause the fuse to get hot enough the melt the solder inside the fuse.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
