Posted by Owen Aaland on October 28, 2009 at 20:10:25 from (207.13.114.170):
In Reply to: 574 runs lean posted by chadd on October 20, 2009 at 16:32:59:
A.D. said: (quoted from post at 19:43:23 10/28/09) As a follow up, I had installed the venturi and it's seating ring upside down.
The the venturi's big end goes up towards the manifold, and the seat ring will have to be flipped on the fuel bowl so it will bolt back together properly.
I've seen that happen before. The way you can always be sure that the venturi is in correctly is the part with the smallest inner diameter will always be where the main fuel jet ends. That puts the lowest air pressure at the tip where the fuel is drawn out.
At full load there is very little manifold vacuum. The decrease in size of the venturi causes the air to have to move faster at that point lowering the air pressure enough that atmospheric pressure on the fuel in the fuel bowl pushed the up the jet.
At idle or light loads there is enough manifold vacuum so the venturi is not necessary but without it the fuel flow will drop off just as the engine needs more. By using the choke you can create a vacuum in the manifold allowing the engine to still draw fuel out the main jet.
Today's Featured Article - New Hitches For Your Old Tractor - by Chris Pratt. For this article, we are going to make the irrational and unlikely assumption that you purchased an older tractor that is in tip top shape and needs no immediate repairs other than an oil change and a good bath. To the newcomer planning to restore the machine, this means you have everything you need for the moment (something to sit in the shop and just look at for awhile while you read the books). To the newcomer that wants to get out and use the machine for field work, you may have already hit a major roadblock. That is the dreaded "proprietary hitch". With the exception of the
... [Read Article]
Latest Ad:
[More Ads]
