Posted by JMOR on October 29, 2009 at 08:54:22 from (72.181.156.161):
In Reply to: H farmall generator. posted by KEB1 on October 28, 2009 at 20:52:03:
Bob O2 Martin said: (quoted from post at 10:22:05 10/29/09) Thanks a lot for the responses. That helps a lot.
Most of that type of hookup I'd hooked directly into the battery terminal with a fused wire.
Is there a problem with doing it that way rather than hooking into the voltage regulator?
It probably isn't a problem, but it could conceivably reduce generator output due to current limiting function of the VR unit.
I personally always thought it was a strange design & ultimately, I guess the designers did too, as it was eventually designed out.
What it did, was allow the generator to supply loads without regard for (i.e. independently of) the current sensing coils inside the voltage regulator. Leaving that current sensing coil to limit only generator current to the battery, whereas VR units without the "L" terminal sense the total generator output current (loads + charging current to battery).
As I said, I always thought it a strange implementation.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
