Re: Rear end fluid
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by The Red on April 23, 2000 at 13:39:43 from (12.75.196.37):
In Reply to: Rear end fluid posted by TxFarmall H on April 23, 2000 at 13:32:16:
Jason you are speaking of the Farmall H? Did you pull both drain plugs when you drained? There is one underneath the plate between the liftall and the rear end. And if you really want to get all the moisture out, also unbolt the belt pulley face and tap it loose. You will get a quart of 90W along with moisture.
Post A Followup
: Re: Re: Rear end fluid
