Re: H farmall generator.
Posted by Bob M on October 29, 2009 at 10:40:21 from (151.190.254.108):
In Reply to: Re: H farmall generator. posted by John T on October 29, 2009 at 09:53:24:
John T - I suspect the 4 terminal regulator MAY do a better job regulating voltage seen by the battery since it eliminates the voltage drop occuring in the wiring between the VR's BAT terminal and the light switch when the lights are burning.
OTOH it's probably only the matter of a couple tenths of a volt - likely less than the voltage tolerance of a typical VR regulator relay seeting.
That's just my theory however...
Bob M
