I’ve pondered this myself. Took it so far as to discuss the feasibility of designing a solid-state voltage regulator with a couple different electrical engineers and circuit designers. Here’s what I learned:
1 - The cutout relay function can easily be replaced by a suitable diode. In fact the “solid state cutouts” sold to replace OEM style cutout relays are exactly that: A diode of the proper current and peak reverse voltage rating packaged inside a tin can or potted in epoxy. Only downside is a there's small voltage drop (about 1 volt or so) that occurs across the diode when current is flowing. Fortunately this is not really an issue for a generator/cutout system.
2 - The voltage and current regulation function is a bit more complicated. But it too can accomplished using an integrated circuit voltage regulator, a few resistors/capacitors and a power transistor. Problem is designing/testing a circuit robust enough to stand up to the transient voltage/current surges, temperature extremes, vibration, moisture, possible reverse polarity connection, stray currents from welding, etc. that must be endured by a regulator in tractor generator charging system service. Also the good regulator design would be so its failure doesn’t cause it - or another system component (generator) - and connecting wiring to overheat and start a fire. (Product liability!)
3 - Now factor in the relatively tiny market for a 6 volt, solid state voltage regulator.
Bottom line is recovering the development cost to design/build/test/sell a handful of regulators is probably simply not worth it. Otherwise someone would already have done it.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
