Wardner said: (quoted from post at 18:19:07 10/28/09) M Diesel,
If the cylinder is mounted upside down, lifting of
the hitch happens as the piston rod retracts. The
displacement of the rod must be subtracted from the
displacement of the cylinder. That means less force
in a shorter time. I am not going to bother doing
the math but the push of a cylinder is ALWAYS
greater than the pull. You can take that one to the
bank.
My point being that the cylinder is always between the same two mount points. He is not fabricating mount points for it. On all the 3 point units I have seen, expansion = raise.
And I have done that calculation more times than most. Far more times. :roll:
If it has the mounts for two cylinders I prefer to split the volume into two 3" small rather than one 4". It eases the role of the rock shaft.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
