Re: I've had a bit of a disappointing day.
Posted by glennster on October 30, 2009 at 05:14:12 from (24.14.63.246):
In Reply to: I've had a bit of a disappointing day. posted by Mike CA on October 29, 2009 at 18:28:51:
mike, mike, mike, always measure twice and weld once!!!!!!! you need the grille insert to set up the position to weld the patch in. is the used piece in crooked? you may need to do a little metal work with a hammer and dolley to massage it for a better fit. if not, do you still have the insert i made for you ? you may need to remove the bad one and then weld in the replacement, however, be sure to fit it first. now if you would transfer to a navy base near yorkville, i could weld it up for you!!!! with all the rain we been having here, i think i saw a submarine in the headlands on my cornfield this morning!!!!
