Re: 52 M Carb Problem
Posted by Bemidji 52 M on October 30, 2009 at 06:49:31 from (209.191.211.226):
Been working on this off and on and spent some time on it last weekend. Well after draining the fuel tank since somebody basically destroyed the sediment bowl, along with the valve not shutting they also took out the screen. The carb does need a complete rebuild. So the brass tag says 50983dc where can I get a rebuild kit at, this website does not list that part number and I have no idea what throttle body is on the tractor. Thanks for all your help!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
