Re: Super C - PTO Lubrication How ?
Posted by Janicholson on October 30, 2009 at 07:03:57 from (199.17.6.222):
In Reply to: Super C - PTO Lubrication How ? posted by dpski on October 30, 2009 at 06:45:18:
The internal path of the oil on the gears, and drain back from that flow, is captured by the PTO gearbox to fill it in use. I would pour in a pint of the total gear lube through that top hole, Excess will just flow back inside the dif. JimN
