Re: Crankin' an' pullin' an' gasoline fires
Posted by John G. Hasler on October 30, 2009 at 10:16:03 from (174.124.36.161):
In Reply to: Crankin' an' pullin' an' gasoline fires posted by Lennh on October 30, 2009 at 08:56:06:
> I"d defer to engineers on this one, but it looks
> to me like the drawbar "geometry" (got a B in
> high school) brings most of the load ahead of
> the rear axle and tends to pull the front end
> down.
Most importantly it brings the load in below the plane of the axle. Pulling back on a point below the axle tends to pull the front of the tractor down. You want this because the engine is trying to lift it up.
Another tip from an old manual: if you think there is any chance your tractor is frozen to the ground always back up to break it loose. If you pop the clutch in forward with the rear tires frozen down they may stay fixed while the entire tractor rotates around the axle. Guess which way it rotates and who ends up on the bottom.
