Re: Interesting problem solved on Farmall A
Posted by Tom Fleming on October 30, 2009 at 16:18:17 from (206.193.247.91):
In Reply to: Interesting problem solved on Farmall A posted by Tom Fleming on October 29, 2009 at 18:01:14:
Thanks Scott, I appreciate the kind words. That is why I posted it, as someone else may run into this at some point. Not quite sure I would have figured it out as quickly if the previous owner hadn't stated that, "they had the engine professionally rebuilt".......God knows that is becoming more and more of a scary statement on this site!
It ran like a champ with the distributor, and it just didn't make sense that the mag wouldn't time right. It then dawned on me that the distributor was 360 degree's adjustable for the timing..... not immediately obvious. And the only way for a mag to out of time is if the pinion shaft is out of time or the mag internally is out of time.
I had a similar issue with an F-4 mag, but in this case, it was the mag being out of time internally. Bought it off a guy who was getting out of tractors. He told me how he rebuilt it. Threw a decent spark, but was once again couldn't get the tractor to run right, as when you would advance the spark the engine would spit and sputter and die. Also, the impulse didn't seem to trip at the right time. Spent 2 weeks monkeying with the timing disk on the mag drive, but couldn't seem to get it right. Then on a lark, I opened the mag up and found the rotor to be out of time with the mag shaft. Got it properly timed, and ran perfectly. I am definately loosing faith in peoples ability to read directions............ :cry:
Hopefully this post will help someone in the future with similar issues.
