Re: I've had a bit of a disappointing day.
Posted by paul case on October 30, 2009 at 16:32:13 from (174.158.115.153):
In Reply to: I've had a bit of a disappointing day. posted by Mike CA on October 29, 2009 at 18:28:51:
i have had some luck with broken stud or bolt removal by welding a oversized nut to the stud . even if its broke off flush sometimes this works. i use a mig welder or arc with a small rod. if it sticks good and you wait for it to cool some they generally turn right out . i think the heat helps. this may not be an option if youre not a fairly good welder and if your having someone else weld on your grill it doesnt sound like you weld. i think welding a nut on is a whole lot easier than drillin any day! my $.02 worth
