Posted by old on October 30, 2009 at 17:40:19 from (4.245.10.83):
In Reply to: farmall A missing posted by dmiller on October 30, 2009 at 14:58:41:
Just because the valves open and close does not mean they gap is correct and that needs to be checked and or adjusted. Also just because a plug has spark does not mean it will fire like it should in the cylinder. I would check the valve tappet gap since you have the valve cover off any how and also try a new plug in that cylinder. I might also swap a plug wire from one of the other cylinders and see if the miss follows the plug wire, oh and you can do that with the plug also
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
