Re: diesel no power
Posted by robert in Mi on October 30, 2009 at 18:45:36 from (64.12.116.73):
In Reply to: Re: diesel no power posted by tractor vin on October 30, 2009 at 17:50:19:
The air cleaner system is nice and clean and been refilled with 30 wt oil, the timing was checked and was slightly retarded, that made a very slight difference,the fuel shut off is completely forward. There is not a blower so that is ruled out. I am yet to check the valve lash i believe it is supposed to be set at .020 with the engine at operating temperature please correct me if i am wrong i will also make sure to check the compression tomorrow. thanks for all your help so far.
