Re: Where do I check and fill hydraulic fluid
Posted by mike keefe on October 30, 2009 at 19:05:27 from (76.24.123.126):
In Reply to: Where do I check and fill hydraulic fluid posted by mike keefe on October 29, 2009 at 07:21:49:
Again thank you all. I found a Wagner Iron site on the web. The Hydraulic fluid is filled at the vented fill plug as Scott wrote. To check if it is filled you measure from the fill pipe and the fluid should be 4 inches below the base of the filler pipe.
