Re: Starting Issue with Farmall 140
Posted by xcubber on October 30, 2009 at 19:17:34 from (4.224.189.7):
In Reply to: Starting Issue with Farmall 140 posted by Raymond Joyce on October 30, 2009 at 17:13:31:
I have either a "73 or "74 140 12V, it has a solenoid for use with the key. Can"t remember if the 6V models have a key or not, if the 6V solenoid is bad the starter wil do nothing. If you jump the battery direct to the starter it "should" turn over but not start unless you have the key on, IF it uses one. IF you have a solenoid on yours simply jump across the solenoid terminals and see if it cranks, if so then the solenoid is bad. BE SURE it"s in Neutral!
