Re: Super A missing
Posted by ScottyHOMEy on October 31, 2009 at 06:43:43 from (71.241.193.92):
In Reply to: Super A missing posted by fredmich on October 31, 2009 at 05:12:06:
Shaggy's ideas about the valves is good. You could run them for clearance at the top, but a compression check might also be worth the mininal effort that takes. Check them all but the two where the electrodes were burned up would be suspect.
