Re: ammeter needle bouncing
Posted by Janicholson on October 31, 2009 at 07:09:59 from (64.61.211.132):
In Reply to: ammeter needle bouncing posted by matt from WI on October 31, 2009 at 06:01:21:
The three most likely causes are:
1} A connection in the system that is intermittent. This includes both control wires from the exciter supply through diode, and the #2 terminal sensor wire. The heavy current carrying wire, and the amp meter and connection to the starter supply terminal are also involved. A failing amp meter can also do it. Sometimes wiggling connections will work to find it, sometimes it just must be taken one connection at a time.
2} The alternator can have an intermittent connection in it (either regulator, or stator/diode pack)
3} The brushes in the alternator slip rings can be hanging up and or worn out. Common with used alts.
It should be rock steady.
JimN
