Re: Super A missing
Posted by Janicholson on October 31, 2009 at 07:19:30 from (64.61.211.132):
In Reply to: Re: Super A missing posted by fredmich on October 31, 2009 at 06:13:45:
An old set of points worn to >.025"gap can run OK but look bad.
When replaced, the new points gapped to .020" run rough. This may be because of a worn distributor shaft bushing that allows the timing to go berserk. If play can be felt in the shaft from moving it in all directions (except in and out) it needs bushings, and maybe a shaft. The play should be less than .001 measured with a dial indicator. Centrifugal advance weights and springs can also be an issue. If weak or broken, advance stays in the high speed range at idle. Good luck, let us know what you find. JimN
