How I unstuck my W-400
Posted by Wardner on October 31, 2009 at 09:49:02 from (4.154.245.99):
1. Remove spark plugs and empty a can of PB Blaster into cylinders. Let soak for a week.
2. Remove valve covers and check for stuck valves. All were good. Give them a shot of PB Blaster anyway.
3. Remove oil gallery plug on left side of block at rear. Pump in oil.
4. Block up left side of tractor. Attach wheel attachment and 12' wooden lever. Select 5th gear, high range on TA. Rock the lever both ways. Nothing happened.
5. Add three tires (about 125 lbs) and rock again. Nothing happened. Hit starter and I got movement. Think I will let it sit for a few more days before doing that again.
third party image
