15-30 (22-36) Gear Removal Problem
Posted by Tom in Iowa City on October 31, 2009 at 16:36:57 from (173.21.35.134):
I have my 22-36's main frame completely stripped, EXCEPT for one thing.
I have removed the brake drum and both right- and left-hand bearing cages. The problem is, I cannot figure out how to remove the bull pinion shaft and the bull gear hub and spur gear pinion unit.
Thanks,
Tom
