Re: Rearend of H
Posted by Wayne in MN on October 31, 2009 at 16:48:21 from (24.181.144.115):
In Reply to: Rearend of H posted by FarmallBear on October 31, 2009 at 14:15:31:
Likely the inner axle bearing is the problem. Best do some careful checking so one ball doesn't come out of the bearing & punch a hole in the bottom of the rear end casting.
