Re: What's The Deal With 1468?
Posted by Owen Aaland on October 31, 2009 at 16:54:27 from (207.13.114.170):
In Reply to: What's The Deal With 1468? posted by Brownie 450 on October 28, 2009 at 18:34:11:
M Diesel said: (quoted from post at 18:43:59 10/29/09) To V or straight isn't the issue. Makes no difference in power per cylinder. Nearly all V cranks have fewer main journals (and I'm pretty sure the 68s are like this) and the increased crank flex eats the crank bearings faster.
You can add to this the fact that the DV550s had a crankshaft that was not regrindable. Standard size only bearings. The block does not use sleeves either so the whole engine is much more expensive to overhaul.
