Re: Rear rim hardware on a 1941 Farmall B?
Posted by J Huff on October 31, 2009 at 16:57:53 from (75.106.107.156):
In Reply to: Re: Rear rim hardware on a 1941 Farmall B? posted by ScottyHOMEy on October 30, 2009 at 20:57:35:
Thanks to everyone for the replies.
Scotty: The squareheads are all there, recessed into the lugs. Most are flush with the outside edge of the lug, but several have pulled at least 3/8" through the lug, like the one in the blurry close up.
Yes, 3.5" is the exact lenght I need, I am going to take the lug's measurements into the hardware store and see if I can first find a carriage bolt with a square shoulder that will fit tightly into the lug, but if not, I am glad to hear that a bolt / washer combo will work. Thank you very much.
