Re: ACK! Removal of broke thread tap?
Posted by Dr. Bert on October 31, 2009 at 17:05:09 from (72.36.57.58):
In Reply to: ACK! Removal of broke thread tap? posted by Mike CA on October 31, 2009 at 16:43:20:
Mike CA: When that happened to me, I took a pair of good quality needle-nose pliers-ground down the jaws a little-so they would fit in the grooves of the tap and with firm, steady pressure on the handles backed the tap out far enough to grasp with vise grips. May work for you--Good luck.
