Re: ACK! Removal of broke thread tap?
Posted by gene bender on October 31, 2009 at 17:56:49 from (67.55.226.179):
In Reply to: ACK! Removal of broke thread tap? posted by Mike CA on October 31, 2009 at 16:43:20:
There isnt any way you will drill it out as the tap is harder than the tap. Get a dremmel tool with carbide 1/8 cutting tool and be careful.The tap extractors arent that great depending on how bad the busted tap is stuck.As a maintenence person on third shift had way too many to remove lots of tricks mite be better taking it somewhere to have it removed will save you lots of money buying tools ect and keep you from ruining the part.
