Re: Farmall 200 ID plate
Posted by D Slater on October 31, 2009 at 19:08:54 from (71.164.46.231):
In Reply to: Re: Farmall 200 ID plate posted by Darald in Sk on October 31, 2009 at 16:39:56:
Unless a casting was replaced sometime the tractor would be assembled sometime after the latest casting code date. Posting some serial numbers that may be in the area of your tractor.
Month is first, year next, first chassis serial # built that month, followed by the first engine serial number installed in a tractor that month.
oct. 55--8996--17166
nov. 55--9549--20011
dec. 55--10232--22004
jan. 56--10904--24697
feb. 56--11600--26588
mar. 56--12686--28537
If tractor has the original engine see which month the engine serial # falls in. Tractor serial # would be somewhere between the first chassis serial # of the month and the next month it falls in. IH probably counted tractors made the last 2 months of 55 as 56 models.
