Re: ACK! Removal of broke thread tap?
Posted by Wardner on October 31, 2009 at 19:18:14 from (4.154.244.4):
In Reply to: ACK! Removal of broke thread tap? posted by Mike CA on October 31, 2009 at 16:43:20:
I hesitate to mention this because I don't know
exactly what the problem is.
I am assuming that the hole is a through hole into
the water jacket because you are working on the
block. Yes, a torch will work but you haven't got
one. Cast iron will not oxidize as fast as steel
when one hits the oxygen lever. I torch out steel
pipe from iron fittings all the time.
You said there is only a small piece of the tap
and it is near the end of the hole. Let's assume
that the last 1/3 of the hole is expendable.
Let's also assume that the cast iron surrounding
that 5/16th hole is about 1" thick. That's
reasonable because the pattern maker would have
beefed up areas around tapped holes.
You could take a piece of 1/4" pipe (that's a
nominal size, actual size is over 5/16th" on the
ID), cut it to fit between the inside of the water
jacket and something solid. If there is nothing
solid, put a piece of heavy flat bar in there as a
bridge. The pipe gets centered on the hole and
is tight. Now drive the tap through the cast iron
into the pipe.
Install the new stud with Threadlocker or epoxy. I
think 1/2" of thread in the cast iron would be
enough but you will probably have more. I don't
think you will have a big divit on the back side.
Just four small thread tear outs. If you are lucky
the only damage will be to the tap as it shatters
into small pieces.
If you are not lucky, and you cave in the whole
side of the water jacket, will you forgive me?
