Mike, I've been there. The first thing to do is walk away for a few minutes.
I would try a punch first - sometimes you can break them into smaller pieces while you try to back it out. If it's flush try to weld a nut to it. Sometimes the heat really helps.
If all else fails I'd take a torch to it. I know it's a blind hole, but I've done it before. Wear good eye protection and get the tap red-hot then put just a little O2 to it. Is it a 5/16? The smaller it is the more difficult it will be. Good Luck
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
