Re: Starting Issue with Farmall 140
Posted by WalJohn on November 01, 2009 at 03:16:27 from (66.82.162.19):
In Reply to: Starting Issue with Farmall 140 posted by Raymond Joyce on October 30, 2009 at 17:13:31:
Make sure you have large cables. Auto cables won't work on 6 volt. 0 gauge with soldered terminals. Learned from the great late Hugh McKay for my 61 140.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
