Being how it is only a 5/16 tap,you might get it out with a tap extractor,blow a lot of compressed air in the hole first to loosen all the metal shavings or trybacking it out with a punch that is pointed on the end.If all else fails hit the center of tap with a good punch in the center and try and crack the tap,use compressed air and a small pointed awl or something simalar to move it around and get the peices out,if you were around middle Tn I would get it out for you.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
