Re: ACK! Removal of broke thread tap?
Posted by Dave_Id on November 01, 2009 at 07:13:01 from (63.246.177.253):
In Reply to: ACK! Removal of broke thread tap? posted by Mike CA on October 31, 2009 at 16:43:20:
dblair has the right solution. EDM is really the only good way to remove a broken tap. If your tap is a carbon steel or M2 high speed tap, then you may be able to remove with a carbide burr, but a torch won"t touch an M8 high speed tap, and you may just destroy the casting in the process. You probably had a cracked tap that it would break that easily or one that was mfg"d in China and improperly heat treated.
