Re: Farmall H PTO repair or replacement
Posted by Dave S. on November 01, 2009 at 08:10:04 from (208.92.171.49):
In Reply to: Farmall H PTO repair or replacement posted by Alan Martinson on November 01, 2009 at 06:32:41:
You should be able to do any of the things you mentioned. If it was mine I would take them apart and clean everything use the best parts from the two, replace seals and reinstall.
You do not have to remove the deck, just drain the oil down some so it doesn't run out or raise the rear end(back up on a steep incline or jack it up and block).
