Re: Clutch shaft on H
Posted by Janicholson on November 01, 2009 at 16:22:04 from (64.61.211.149):
In Reply to: Clutch shaft on H posted by FarmallBear on November 01, 2009 at 16:15:27:
Take a photo of it now, then remove the other two bolts from that coupler. Remove the Throwout bearing carrier, and it will wiggle out. It is easier with three bolts from the pressure plate used to compress the clutch (take them out at 120 degrees apart, then put them into three holes in the PP where the levers are located. This compresses the clutch. JimN
