Re: Traction in the mud question
Posted by mkirsch on November 02, 2009 at 04:47:44 from (64.80.108.57):
In Reply to: Traction in the mud question posted by KenB_Texas on November 01, 2009 at 20:18:50:
Ken,
Your biggest concern with the duals is tire diameter (height). The outer wheels should be the same diameter, or shorter, than the inner wheels. Don't worry about tread pattern; there are plenty of tractors out ther with four different tires on them. It's common to take an old worn set of tires off the tractor and use them for duals.
