Re: Torque wrenches
Posted by ET on November 02, 2009 at 09:20:53 from (134.179.104.135):
In Reply to: Torque wrenches posted by Dave H (MI) on November 02, 2009 at 07:16:53:
I own several torque wrenches. The ones that are acurate on the upper end of the scale are not as acurate on the lower end. Like someone else here said investing in a good one is well worth it. Before you say your will only need a torque wrench a coulpe of times a year you should consider that every piece of hardware has a torque and should be tightened accordingly. I find more things are over tightened than under tightened. Things that cover a large plane like oil pans and manifolds have less tendancy to seep oil or warp if tightened evenly. On clicker torque wrenches that have a screw type grip to ajust the settings be sure to back it off to zero when you get done to relive presure on the internal tortion bar and maintain its accuacy
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
