Since we're going to talk about technique, I too would avoid that area with the tractor like the plague. Even with duals you're going to at least tear up the area, and probably get good and stuck.
What did you intend to do to improve drainage without digging a trench? Other than re-grading the entire area... Those are really the only two practical choices, and as someone said, you can't work mud.
Really your only choice to remedy the immediate problem is a trench. That may be better handled by a backhoe or trackhoe, something that can sit up where it's high and dry and reach down in to dig the ditch from the side, much like a roadside ditch. You'll need to hire some heavy equipment to un-stuck the 300 after you bury it, so you may as well hire them outright to do the actual work.
Later on in the spring you can bury a 4" drainage tile and re-grade the area.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
