Re: SA electrical problems
Posted by Janicholson on November 02, 2009 at 15:26:42 from (64.61.211.208):
In Reply to: SA electrical problems posted by Mark on November 02, 2009 at 15:12:08:
First is the polarity of the coil. If it has an alternator, it is very likely a negative ground battery and charging system. This means the coil negative should be grounded (through the distributor/points)
Second is the timing. With #1 on TDC, The points should just be breaking, with the rotor pointing to #1 wire terminal in the cap.
If these are right, pull the coil wire away from the cap, and place it 1/4" away from the block.
Open the cap, and use the tip of a screwdriver to open and close the points. If there is a nice blue spark it should run. If not suspect the coil. JimN
