It very well could be a bad coil from what you describe. As far as replacing it, you have the choice. a) get a 6v coil, and continue using a ballast resistor inline between the battery and the coil or b) get a 12v coil, which delivers the same output to the distributor as the 6v, by being wound differently internally than the 6v coil, and eliminates the need for the inline ballast resistor.
The badly burned points could be a matter of the ignition being left on with the tractor stopped (also hard on coils!), but could also be a symptom of too much voltage. What do you have for a ballast resistor? If one of the old Chrysler types, could it be hooked up to the wrong side (the side without resistance) so that it's delivering the full 12v to the 6v coil?
As far as what goes where, the wire from the coil to the points in the distributor should be the same as the ground on your battery. If you're like most 12v and use a negative ground, the wire to the distributor should also be on the (-) stud of the coil, and the lead from the battery to the coil on the (+) stud.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
