Re: SA electrical problems
Posted by JMOR on November 02, 2009 at 18:05:19 from (72.181.156.161):
In Reply to: SA electrical problems posted by old on November 02, 2009 at 15:12:08:
Janicholson said: (quoted from post at 20:15:26 11/02/09) With respect, the resistor between the coil and distributor is very different than having it before the coil. The primary current is strongly affected by the condenser in the distributor. This should be directly connected to the coil neg side in this case. The companies and that built coil and point systems for years did not put the resistance between the interacting components. JimN
With all due respect, Jim, when reduced to it's simplest equivalent, it is a simple series circuit, and we both know position of the elements in the series does not matter.
It is just a physically cleaner installation wiring wise to put it where the makers put it.
third party image
